onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Thu Aug 11, 2005 11:45 am
SWEET, so the sohc w/ the 9:1 compression ratio doesn't have the ait?
Thanks, I've been trying to figure out what my 89 was for a while, hahaha.
THANKS!
And about the wideband -> analog, yes, like Import_Ant said, some of them have an analog output. However, depending on your budget, which I think you are trying to keep it as low as possible, you may want to just weld an extra bung & only use wideband for tuning/testing, then plug it up for normal driving.
Wideband life is much lower than regular o2. However, if you have the money to replace your wideband every few months or so, maybe a little longer - varies w/ the wideband - how it's installed - how it is driven - etc, then it would be a good way to be able to keep an eye on ur a/f ratio.
