Iamjohnhayes wrote:Can I remove it w/o massively screwing things up?
Short Answer: no.
Slightly less short answer: you can remove it, but only if you really know what you are doing - there have been a few members who have successfully removed the pcv system... however they are also now idling @ 1k - which isn't that bad, but also unecessarily high.
And when wild_maxx said it connects to the black box on the "right" side... it would be the other "right" i.e. left side of the cover if you are looking at the engine from in front of the car.
