:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Tue Feb 01, 2005 10:48 am
First off, forget about OBD-I, OBD-II, whatever...means nothing here.
That being said...
To use ANY S13/S14 DOHC motor in an '89-90, you need a '91-94 wiring harness and ECU...but it's mostly plug-n-play.
You will also need a DOHC S13 distributor with external coil, and a '91-94 MAF sensor.
Now, the '98 motor makes it harder b/c you need the S13 coolant temp sensor (different plug on '96-98 motors)...and the plugs for the IACV and such may be different...this is why it is MUCH easier to just get an S13 DOHC motor with all the accessories, including intake and exhaust manifolds...and the "down pipe" that comes off the factor exhaust manifold.
- Brian
