kae to kade wiring help
biggin07
Car: 89 240sx with a little done to it
as topic said i need help on the ka24e to de wiring. i am stuck on the wiring under the dash for your tach so far i cut and solder the wires i matched them. i matched them i checked and checked but for some reason my tach is still not working. here is wat i did so..
matched ones
yellow with red strip to yellow with red strip
black to black
red to red
green with brown strip to green with brown strip
yellow with green strip to yellow with green strip
orang to orange
blue to blue
blue with black strip to blue with black strip
green to green
green with white strip to green with white strip
Wire could not find dubles to
Ecu:
green with yellow strip
green with black strip
Plug:
purple
light green
red with yellow strip
grey
grey with blue strip
red with green strip
biggin07
bump anyone plz help
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
You need to replace the SOHC tach with a DOHC tach, they use different input signal levels.
