You need to find Top Dead Center (TDC) for the COMPRESSION STROKE in order to time the ignition distributor. The end of the shaft will look like a "D", when looking into the distributor hole while standing at the drivers side front wheel well. Actually, it (the "D") will be more of a "11:45" position, NOT quite "12:00"; if not, then remove, and reinstall until the above position is obtained.jday240 wrote:1990 S13 240 w/ a KA24E
When the engine is set to top center which direction is the oil pump spindle pointed? (| , (\ , (/ , |) ? I was reading earlier that the rotary button should point to the #1 plug wire at top dead center and the direction of rotation is CCW 1-3-4-2. Which direction is the half moon supposed to sit?With all of the above true my base timing should be set enough to run and check w/ my timing light w/ the TPS disconnected.
