nissanfanatic »
https://forums.nicoclub.com/nissanfanatic-u21678.html
Fri Dec 16, 2005 4:52 pm
Quote »Does anyone know of a way to read total timing numbers on the SOHC motor?[/quote]Use a timing light at the dyno. Under WOT, read timing.
Wow... and that was on max smoothing... Definatly look at plug gap.. Although, most of the high HP cars curves look smooth because thier graph reads "200-300-400-500" while yours reads 180-200-220-240" so of course, yours is more defined.
But if you ask me, it looks like you need to pull some fuel from about 4000rpm on AFTER you ensure timing is correct. Under 11s can give you that rigidy looking curve. I pulled some fuel after I dynoed and noticed a smoother pull as well. It seems good now, but once you get that graph looking like the beginning of a roller coaster, its nice...
