SCKA24E »
https://forums.nicoclub.com/scka24e-u25448.html
Mon Aug 29, 2005 5:03 pm
alright i took dissconnected the tps, turned car off , on,set idle to 700 , set timing to 3rd mark from right , turned car off and set tps to about .41-.43..... but my car still runs half ****ty, it idles at about 750 when cold and drops a lil when warmed,, qany suggestions, my car accelerates real slow if i try gunning anywhere below 3000 roms, so could ity be my TPS is bad, or MAF , the voltage on my MAF 12v constant (white wire ) is about 13.5 the black and white is about 1.7 and the ground is at about .4-.7 ialready regrounded, where is there a good ground , cause i have it grounded to the - batt terminal, , and i get about 250 on a full tank , so im getting killed over here. i waste about 45$ a week for gas, so please if u can help me out , ive already changed aLL THE OBVIOUSE 02, CAP ROTOR, FUEL FILTER PLUGS, , AIR FILTER, PCV,. SO IF ANYONE CAN HELP I D BE GREATFULL, THANX
