spindrift187 wrote:off topic a little:
How do you like the solid lifters? i heard they are a bit noisy, but if I can get away from the damn OEM ones that would be worth it.
Well, thiey're great. At first, I set the valve clearance to what the recomended and it was a bit noisy. So, instead of measuring the clearances, I just do it by feel. With the clearances tighter, the noise drastically lowered. I did some shopping before I found them. I found that at parts stores, a complete set of rockers and shaftes were around $600, and about $500-550 at the dealer. The solids were only $300, and I got new shafts from the dealer for like $150. So, IMHO, the slightly noisier solids is a small sacrifice for a superior and less expensive upgrade over factory. I just do a quick check every oil change and adjust any I feel need to be. Plus, now I can run any cam I want and not have to worry about milling the cam towers cause these will adjust for the difference.
It's cool how the guy at HybridKA "makes" them. He takes your old ones, drills a hole where the factory hydrolic lifter was, taps the hole, and uses the end of a pushrod he threaded for the lifter. Brilliant!
I am very satisfied with the rockers. Now I need to complete my "quick remove" valve cover bolts that the old school hot rodders use.
