niznos wrote:4. Mount as close to the throttle body as you can on the intake tube to insure that the nitrous stays dense as it enters the manifold instead of dispersing or even running backwards while it trys to expand.
I hope it helps and if I am dead wrong on something, I am sure it will be caught by someone rather quickly.
You actually want to mount as far away from the throttle body as possible. You want the nitrous charge to disperse- that way you have the most even distribution of nitrous in your intake system. If you spray too close to the throttle body and fail to distribute the nitrous evenly, you all of a sudden have cylinders that are pushing drastically different amounts of power- and that's a great recipe for engine failure. Spraying farther away from the throttle body won't cause the nitrous to run in reverse. Your engine is sucking in quite a bit of air at full throttle- it's going to pull the nitrous in as well.
If spraying far away from the throttle body is bad, why would ZEX make an air filter with the nitrous nozzle in the top?
If you're running a wet shot, things are slightly different. You want to be as far away from the throttle body as possible so you can get a good mix of air/fuel/nitrous, but you don't want to be so far away that you take the chance of igniting an air/fuel mixture inside the intake system. It's a little more tricky. You want to get just close enough to have good nitrous/fuel dispersion without dropping gas all over your intake tubing.
