KADET smokes alot
aaronscomp
Car: s13
MY KADET is smoking alot and its idleing @ 2g's which doesnt seem right to me, whhen its just sitting it doesnt smoke at all but when ever i give it gas it just pours smoke, i also cant hear the turbo spool up. im not running wideband im looking to but also can someone suggest what wide band setup i should run? im verry new to the kadet's so can someone kinda help me out thanks
setup garret t28 turbosr20 sidemounteverything else is stock
This was actually my freind that posted using my account because i guess i didnt log out the last time i was on his comp. his car is actually idling at 1350 he's running stock injectors which i told him to get some stock sr ones atleast the car shoots out black fuel when u hit the gas and when its just idleling it shoots out white smoke, it also runs really really rich
Modified by aaronscomp at 9:49 AM 10/27/2008
Modified by aaronscomp at 8:55 PM 10/27/2008
Darchangl
Car: 95 240sx Ka-t (in progress)
could it be the turbo seals?
aaronscomp
Car: s13
Darchangl wrote:could it be the turbo seals?
nah there good
480sx
Car: 1996 Pearl White 240sx
Why do you think they are ok?
Compression check? Hows the car running?
aaronscomp
Car: s13
the car idles high and obviously smokes alot, the turbo isnt spooling right,
Modified by aaronscomp at 8:28 AM 10/28/2008
jeff420
Car: too many to fathom
could you give any less information? seriously? why dont you think its the turbo seals? you say the turbo's not spooling right. like 480sx asked, hows the compression? what color smoke?
are you not running any sort of tuning? what about fuel injectors?
aaronscomp
Car: s13
sorry i added more info. but i have stock injectors, stock maf, no tuning
1unar3clipse
Car: 93 240sx HB, 01 Dodge Dakota SLT
aaronscomp wrote:no tuning
Theres your problem
no seriously now, FMU..? SAFC? nothing..? your just running a turbo setup on a stock KA?
And no wideband....
aaronscomp
Car: s13
oops my b i am running SAFC but no wide band because im not sure which setup to run
1unar3clipse
aaronscomp wrote:oops my b i am running SAFC but no wide band because im not sure which setup to run
See? you gotta mention these things so the people more experienced with KA-T troubleshooting can help you.
Although you should be running a wideband just as insurance to not pop your motor it can greatly help the tuning.Hopefully 480sx can get a better idea of your situation now.
Two-Fortee
Car: 180sx.
What colour is the smoke.
480sx
aaronscomp wrote:sorry i added more info. but i have stock injectors, stock maf, no tuning
Your really lucky that your not able to go into boost for whatever reason, because your asking for a blown motor. Are you SURE you never were able to go into boost? Because if you did theres a good chance your motors blown. I would do a compression check before you bother with anything else.
Man i dont even know where to start. Idling at 1350 is high, but not terrible. Probably have a vacuum leak. You might also try adjusting your IACV screw in and see if you can get it back down to about 1000 or so. If you just slapped in a set of 370cc injectors yea.. Its gona spit fuel out the exhaust.. Adjust your SAFC for -30 all the way across the board and go from there. Also change your oil asap.
Your smoking issue can be a few different things, and you really havnt given us enough information for us to help you. Answer some of our Q's and get back to us.
