the ground wire of the starter got disconnected from the starter. thats why the car wouldnt start. thanx for the help tho. i'll keep it in mind for future progress.stealthy_240 wrote:your battery should be fine then if all the accesories come on. i think it might be one of the sensors that might disable the ignition. fuel pump is good you say. then i think that leaves it down to the green fusible link, interlock relay, clutch interlock. im assuming u got a manual. check the FSM.
