kade throttle body install problem (did a search)
ceniack
Car: 1992 240sx Coupe
1993 JDM Nissan Caravan
2011 Subaru WRX STI Hatchback
2012 Subaru Impreza Hatchback
i have the DE TB on and am using an SOHC cable, however the stock actuator arm thing (what the cable hooks to on the TB) isn't right, so i went to swap on my CA one and the hole is too small for it to slide on, did you all that just swapped file it out or smething?
thanks
-terry
*edit* NM figured out the TB thing, just made the opening larger on the CA part
Modified by ceniack at 11:07 PM 10/19/2006
float_6969
I think that's whaat I did to mine as well. Dremel is your friend...
