kade-t safc 2 tuning help!
murderrsirenss
Car: 92 Nissan S13 vert.
Okay, im a turbo noob, im not going to lie, this is my first turbo car. I have the safc 2 in the car. It has been running HORRIBLE, and very, very rich. I did some online research and looked some things up and I set my hi/lo settings to -27 across the board, and the throttle points as low I could get them, 0% and 1% . The car is running/idling better, but once you get into it, the car starts spitting and spuddering, so what should I do? I got it to stop being rich and pouring smoke everywhere, so i've got a good start.
Thanks for any help/suggestions.
WDRacing
Buy a wide band O2 meter in order to tune the SAFC. What size fuel injectors are you using? If you're interested in having a vehicle run well and you're inexperience with tuning I suggest you ditch the SAFC and go with a Vortech FMU.
WD
