Hey all, Maybe someone has had this problem and can help. I'll try to make this short. Just got done with the turbo on my KA , and am having a little trouble with idle quality, and hesitation at top end. The car will idle fine if I feather the gas for a couple seconds and let off. But if I throw a quick rev, and let off it wants to die. Also at top end starting at about 4500 r's it starts to hesitate a little and cut back all the way to redline. Here are a list of things I have done, and maybe someone can point something out.
All internals balanced, including dampener, flywheel, and pressure plate.Polished CrankEagle RodsWiesco Pistons 9:1Tomei Race BearingsNew water Pump Timing Set, all gears and guidesMLS Head Gasket Ported and machined head with Supertech standard valves and dual springs3 way valve grind and lapCrower Stage 2, 264 Cams NGK Platinum, 1 Step Colder PlugsVortech FMU 12:1AEM WidebandKoyo Aluminum Radiator with dual 10" Fans- Be cool Dual fan controlExtreme Turbo System Complete turbo system T3/4 Turbo with 57mm Compressor and 56mm exh. turbineGreddy type R BOV Tial 38mm external wastegate12" x 9" x 24" FMIC ETS downpipe 3" midpipe with cat delete
Running stock injectors @ 7PSI I have a AEM standalone and 770cc injectors, AEM Map sensor & AEM AITS to run once the engine is broke in. Are the stock injectors maybe my problem ?? Wideband shows 10.4:1 under boost ! Any Help would be great. Thanks D [IMG][/IMG]
