SpazmSi »
https://forums.nicoclub.com/spazmsi-u26353.html
Tue Aug 28, 2012 4:46 pm
SO,
Finally took the time to address some things on the car, I did the ignition hot wire mod, swapped in an intake manifold that I mildly gasket matched and ported. I have a cold air intake, but stock everything else. deleted all emissions, have only an IACV and AIC.
I also set up for TDC Compression and carefully set the DIST base timing making sure the dimple is aligned with the notch and that the rotor is directly under plug 1. I warmed the car, shut off and unplugged the TPS. started back up perfect idle at 700 rpm and set to 20 btdc. car has a new coolant temp sensor..
So before swap and ignition mod, I had a bad stutter around 2200 on hot days with car cold. Also had to max out the dist to get even close to 20 btdc. After swap things have improved everywhere expcept that if I am too quick on the throttle the car stutters terribly.
TPS was set to .5V at closed, and is smooth to 4V but never gets above that. MAF shows .9v at idle and shows smooth increase in voltage up past 2V which is as far as I can open the throttle without blowing up in nuetral. When I stab the throttle quickly I don't lose voltage on the MAF or TPS.
Also, under heavy electrical load lights- seatbelts-defrost I do lose 200-300 rpms. I show 13v at all times on the battery and have a direct power feed to my ignition coil now.
Oh one more thing, with the MAF unplugged I can stab throttle and rev quickly to 3 grand and then choke out. MAF plugged in stab throttle 9 out of 10 times I misfire bad.
HELP I am lost and about to start throwing parts at the car. snapping the throttle to quickly could me what? Crap coil?Fuel Pressure
Any things to check would be awesome....
