kade motor lags???HELP!!!
nismo_power
Car: 91 240sx fastback se
my car runs fine but like at 3.5k to 4k it feels like its gets weak then picks up again what is wrong???for just a sec or two then it will pick up good again...this happens when im in second gear and i kinda floor it then it happens...
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
a suggestion is to check your TPS sensor. check the FSM for the values of resistance and voltage at WOT and full closed throttle.
nismo_power
hmmmm???kinda dumb, i know what and where the tps sensor is at but what is the fsm, wot, and where r they located...also how do i check these things???sorry kinda new at this???
hkssupratt1994
Car: 92 240sx hatch
thats what fines doing but i dont think its my tps sensor i think its my plug wires cause one of thems broken.WOT means wide open throttle.how do you check for that anyway?(tps sensor)
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
yeah, i must agree it really does sound like an ignition problem, but they sometimes can be hard to diagnose.
if you know you have a broken plug wire, shell out the couple of bucks to replace it. and thats only if the problem really isnt in your distributor cap.
the tps sensor has three or four prongs coming out of it when you unplug it. its located on the right side of the throttle body. it looks like a little black box.
get a multi-meter, and first you measure the resistance across two of the terminals. one set of terminals will give you max resistance when the tb is closed and then min voltage when its open. another set of prongs will do just the opposite. and two more prongs are used to test the voltage across these terminals at the same to throttle positions.
all the info is pretty much in the FSM. lemme know.
