punkrocker7788 »
https://forums.nicoclub.com/punkrocker7788-u59193.html
Wed Aug 20, 2008 6:55 pm
ok, this kinda all of a sudden started happening.. Whenever I drive my s13 and are coming to a stop, I push the clutch in to go into neutral and the car will idle low (around 600rpm) and will be ROUGH. then goes back to normal.. then kinda back to low, before it would jump between about 1200 rpm to 600 rpm at a stop.
ALSO
when the car is under full throttle, maybe about 4200 rpm the car will start to lose power. BIG TIME! like it doesn't even wanna accelerate anymore. Then it'll kinda gain power back, then gone again... so on and so forth... does this trough all gears.
Im thinkin that maybe the power loss thing has to do with the fact that the car has a Walboro 255 fuel pump, but stock injectors.( did have 480cc injectors before cause the car was turbo). And maybe I am just kinda flooding it with too much gas. Im going to do a fuel pressure check tomorrow adn determine that problem..
PLEASE!!! Help would be MUCH appreciated!
