S14Magician »
https://forums.nicoclub.com/s14magician-u158577.html
Sat Feb 09, 2013 3:48 pm
Okay so here's the deal. I rebuilt a kade for my 240. Shaved .020" from the head to remove warpage, this caused the lower chain to eat a hole in the main coolant passage in the oil pump cover getting water in the oil. Fixed that issue put on a chain guide. Still am getting water in the oil. I've heard of American engines having this issue when using arp head studs. The arp studs go through a coolant passage on those engines. My question is, is it possible for this to be my problem? Do any of the head studs go through coolant passages in the ka block that run coolant from the block to the head that could be causing water in my oil? I'm lost. Any help is greatly appreciated. Thanks.
