F4ucc »
https://forums.nicoclub.com/f4ucc-u3905.html
Fri May 16, 2003 9:15 am
Yup, two output shafts is all you need, just be sure to replace worn seals!! because mine has a little leak from pinion seal after the KAAZ in......
As for installation, unless you know how to adjust the backlash, get yourself a pro do the job.I got my KAAZ installed at KAAZ USA in LA, great service. 10 hours driving from SF bay........
BTW, did you get just LSD only? I paid $730 plus tax and shipping from Phase-2. It comes with a KAAZ 2-way LSD, one pumpkin gasket, 2 press-in bearings, 2 output shaft spacers, and 2 shaft oil seals. Highly recommended.
Cheers
