yes to the no problem part? or yes to the get a new open diff part?ILoveMyRHS13 wrote:Yes.
jeebus. you welded the guts of your diff, which you will be replacing with the kaaz. the housing itself is still re-usable.Metal Angel wrote:yes to the no problem part? or yes to the get a new open diff part?ILoveMyRHS13 wrote:Yes.
I knew I would get flack for this question because I figured it was probably a pretty stupid question. I don't really care tho. I got the answer to my questionOutToWinPAHC wrote:Lets think about this.
The differential in your car is an open diff with the spider gears welded. And a Kaaz diff fits an open differential case. So you want to know if a case the same as your will fit.
I am being rude, but you literlly comparing apples to apples. The only issue that may pop up if is there is welding spatter all over the case.
Dittoz7 wrote:
