Thrwnsprkz »
https://forums.nicoclub.com/thrwnsprkz-u15288.html
Wed Apr 27, 2005 8:27 am
i helped do mine, enough so that with the proper tools i could probibly do another myself...
yes their was a metallic tint in the fluid and metal on the drain plug, and it was fairly noisy... when we put it in we measured the play in the diff and it came out to be perfect, he said we were lucky and kaaz build a quality unit that didnt need these lil spacers (dont know the name) to adjust it... i dunno if all of their diffs are to spec, i would assume so but their are always variables.
he said if it had too much play then it would be extreamly loud and too little play and it would accually seize up under heat and load, not sure exactly if this could be your problem, but i know its a concern when installing a diff...
just a thought i had, id seek more informative source than me, i hope it helps tho, and that its not your problem
