Place differential back on jack and raise it back up in its original palce. You may need a couple of friends to guide the axles up with it sinces the axles spring out. Bolt the differential back on. Put sway bar back on if you took it off. Then bolt on the driveshaft. Make sure not to leave any bolts loose. Make sure car is level and fill with fluid til it starts to pour out. Tighten fill plug and drain plug from 43-72ft lbs tq.
BREAK IN PROCEDURE
Now that it's installed go to the nearest parking lot and drive in a figure eight pattern. In the straight part of the 8, slowly accellerate to 20km/hr. Once you reach the end of the straight go into neutral with clutch released. Make the smallest turns with the maximum steering angle. Once you get back to the straight , slowly accellerate again to 20km/hr and keep repeating for a period of 30 minutes.
Once that is done, go back to your house and change the fluid again.
This is the exact break in procedure that kaaz recommends in the manual.
After it's installed I don't recommend "testing" it out in public parking lots. (Dont ask)
If there are any mistakes or suggestions or comments please e-mail me at
[email protected].
BE SAFE
I just want to thank Drift Factory for providing a good price on the differential and free bottle of kaaz fluid and free shipping!All this was purcahsed for 895 shipped. But with the extra bottle of oil you will need to purchase it came out to somewhere around $945. Still a great deal and I got a free Drift Factory sweatshirt out of it.
BE SAFE-eliterit
