ka24et turbo kit for ka24det
EckOMaN2k
Hey i want to know will a ka24e turbo kit work for a ka24de? Also are ka24e motors good at making power when its turbo'd?
WDRacing
The Kits will not swap back and forth, everything is different, from manifold to IC plumbing. The KA24E does however make a fine platform to boost, assuming its in proper running order.
WD
EckOMaN2k
Oh damn, yeah the kit was something that someone already pieced together so its basically a universal kit. Which the kit came with JGS log style mani
Borg Warner GM 3 Turbo (very similar to garett T3/T04e,)
vortech fmu 8:1 with a 10:1 disc included as well and all fuel lines needed
brand new fuel filter
set of 4 new wires
4 extra plugs
perirburg fmic (pretty huge)
peirburg bov
all intercooler pipe needed (2.25 hot side 25 cold side)
5 gauges (air/fuel, boost, oil temp and pressure, fuel pressure)
dual gauge pod
steel braided oil feed and drain lines
2 oil pans (one with the fitting already in it, and one to replace incase it leaks)
all vacuum lines you need, vacuum tees
brand new acutuater for ineternal wastegate
down pipe
