I don't usually post on Nicoclub, but there are so many people that are members here that i will give it a shot.
A little background for those that may not know me.
I have a built ka24e, used to have a 60 trim t3, fairly recently switched to gt30r. running ec402 as the brains of my bin. (reference eccs-tech if you're unfamiliar with ec402). its basically a custom U12 (stanza) automatic map with many years of trial and error by many on eccs-tech (hybridka). that being said, here's my setup:
z32 (n62) maf
rx7 550cc injectors
gt30r (.63 a/r)
93 octane
standard ignition
ONTO MY ISSUE:
I am currently trying to tune for above 15psi on my current map. Never was an issue before with the 60 trim, but now ive reached some major hiccups. The problem im having is, according to consult, at about 4500rpm wot at 14-15psi, the timing goes from 14* to 40*! afrs shoot to 13.2s. so yes, thats a problem. according to my maptrace on tunerpro rt, the tp values will shift from the "68" column at 14psi (where they should be) at 4500rpm to like 6 columns to the LEFT (meaning the vacuum section) hence the 38* timing values and 13.2 afrs. any idea why this is happening? Im attaching a pic of the log from ecutalk that kinda shows whats happening, if you know how to read it. Last night, i adjust the timing in the five left columns on the timing map to be the value of what is supposed to be the 15psi timing. just to see if i can at least run the right timing, and i never go above 4000rpm in vacuum.
SO IN A NUTSHELL......why are my tp values changing at wot at 4500 rpm?
Is it the maf? tps? k value? a small green monster?
screenshot of a couple of the log values.....
http://i207.photobucket.com/albums/bb30 ... helpme.jpg
screenshot of how my timing map SHOULD look at this time
http://i207.photobucket.com/albums/bb30 ... ingmap.jpg
put direct links in for if the pics dont load......
