aziankingz »
https://forums.nicoclub.com/aziankingz-u78128.html
Sun Mar 15, 2009 2:35 pm
So I removed my charcoal canister this morning from my ka24e, as well as spray some carb cleaner into the throttle body. I capped off the vacuum lines from the charcoal canister and left the line that connects to the hard line opened. I go to start my car and it starts for half a second and dies..anytime after, it wont start. I did not touch any of the fuel lines.. any idea what can be wrong? Fuel pump works, spark is good.. when the car is put to the "on" position, I hear a hissing noise from the 3rd injector and can see moisture from the injector hole - could a leaking or bad injector be a cause of this? Also..the spark plugs are pretty much drowned with fuel - took them out and airing out the cylinders now. The car was running last night..now after I remove the charcoal canister, it wont start.. . help!
