KA24E wont rev up?
dat925stunna
Car: 90 hatch s13
I have a small issue my ka24e sounds like my plugs went bad i replaced them but then it wasnt so now i bought new ones for nothing but wen its on it idles fine not the head gasket cuz i dnt see any coolant anywhere between the block and head but as i rev it sounds like sumthings rattling in my cat and cant rev up too high ima post pics ima pull the valve cover off and see but wat could it be? i heard the maf but i wanna know anyone that gone threw this
Gabes13
Car: rb20det s13
Probably an exhaust leak.
They can make some weird noises.
Klits562
Car: white s13 coupe
If your cat is rattling its most likely gone bad, if you've ever looked into a cat its a huge mesh of all kinds of precious metals. Well the cat operates extremely hot and after a while the metals break down and they will rattle around in your cat and could end up clogging your cat and if your cat is clogged then your car will not be able to flow exhaust and it will not be able to run properly.
Hit the cat with a mallet if it rattles then there you go.
If you want to test the maf then just let the car idle at operating temperature then unplug the maf. If your idle changes then its good, if not then it could be your maf or both.
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
my ka-et would rev over 4k cause of a head gasket after i changed it, it get the full range
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
dat925stunna wrote:not the head gasket cuz i dnt see any coolant anywhere between the block and head
check what's been suggested already. i just wanted to point out that a bad head gasket doesn't necessarily mean that you will be leaking coolant out of the joint between the head and block.
dat925stunna
Car: 90 hatch s13
its my "meow" great $250 to spend now :tisk:
