Ka24e won't start help!
zer0faith
Car: 2004 Saturn Redline , 2001 Honda Accord v6{saphire}, 1990 S13 RIP :(
1990 nissan 240sx hatch won't start after driving for 20 minutes. shut down while I went to get an estimate which took about three minutes and now it won't start. So what I've done so far...
-replaced spark plugs and rotor button.
-Battery is still good and turns over just doest start.-Less then 1/4 in the gas tank but still primes
Any ideas or suggestion? Cuz I am stumped and pissed.
Modified by zer0faith at 12:33 PM 12/30/2009
zer0faith
update- let the car sit for thirty min and it started up and is now home. What it have it have been? anyone? anyone?
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
im gonna say it was you fuel pressure regulator. its on the back end of your fuel rail... next time its does it pull the vaccuum line off and try to start it. If that makes it start then you know what you need
zer0faith
Hmm thank you I will keep that in mind next time. What would cause that to fail though? Clogging, built up back pressure, low pressure? Just curious
martins_240sx
im not sure...maybe just old age...but definelty higher fuel psi could damage it.
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
The regulator has a diaphragm inside that can leak and allow fuel to enter the engine through the vacuum supply hose causing it to flood out or run very rich. If you pull the vacuum hose off while the car is running and fuel comes out of the regulator you know it is bad.
martins_240sx
there you go/\ but keep in mind that fuel doesnt always have to leak out of the fpr for it to be deamed bad, if you had an inline gauge you could check it against a time/pressure method.
zer0faith
I think I will be checking it tomorrow. But when it comes to doing the gauge and time/pressure method you got me confused bro, care to explain please?
martins_240sx
your fuel system is supposed to maintain pressure for a certain amount of time. if it doesnt you can count your fpr as a possible culprit.
r3v_v3ng3
Car: 91 fastback ka-t
so the engine is cranking right? like the starter is turning the engine over but wont start?
zer0faith
Ya it turned and everything.
Martin_240sx thanks for the advice and ill look into putting in a gauge.
On some good news my complete rebuild kit came in today!
sx moneypit
1986 Toyota MR2
Im with Martin on the regulator.A bad regulator can cause your fuel pressure to be to low or to be to high also. Im thinking you might have an ignition problem,have you checked for spark?
Modified by sx moneypit at 5:58 AM 12/31/2009
zer0faith
So I removed both lines from the pressure regulator and it has a bunch of white powder all inside of it... Which I am assuming it mean that it is garbage now?
sx moneypit
1986 Toyota MR2
The lines may have some residue in them . You can put a vacuum pump where the vacuum hose attaches to regulator to test the diaphragm in the regulator.You will need to check the fuel pressure also.
zer0faith
Ya I have spark... Got electrocuted twice tryin to prove it
sx moneypit
1986 Toyota MR2
Did you have spark when the car would not start?
zer0faith
yup and just to make sure i put in new plugs and rotor button
martins_240sx
that residue is normal, although if you can see it then that means its prolly where you cant as well, and possibly interferiing with the diaphram sealing
sx moneypit
1986 Toyota MR2
So are you getting fuel?
zer0faith
yup plenty of fuel pumping through the filter
martins_240sx
your idea of plenty of fuel can differ from correct amount of fuel. As well as volume of fuel to pressure of fuel. you need to find out how much psi is going to your fuel rail.
zer0faith
i will be next pay check. going to get a new fpr and a gauge to make sure
sx moneypit
1986 Toyota MR2
Good idea, hard to diagnose problems without the correct tools!
zer0faith
Unfortunately I wont be able to finish this. This car is offically for sale. It sucks but id rather sale to to someone who has the time to diagnose and fix since im transferring to sea duty so little to no time to put in wrench time. So now I am in the look for a 240 that is in better condition so i can DD it... Thanks for all your help I do appreciate the effort the people from this site has put in to helping me trouble shoot my car. No worries though i'll still be around picking your brains for more knowledge!
sx moneypit
1986 Toyota MR2
Thanks for your service too! Good luck!
martins_240sx
Good luck man...ship life can get boring quick. I just spent 7 months on the uss new orleans. ports where fun though
zer0faith
ouch I'm going to HSC 9 so ima be doing the world cruise in a year or two
martins_240sx
no idea what that is marine and sailor lingo is way different. i was on the 13th meu.
zer0faith
oh haha my lil brother is in 29 palms he's a marine. what i said was that im getting deployed for about 9 months on a boat
