it'll go to redline then boooooooooog down to 3 or 4k and pull again wierd?Full Street wrote:What do you mean by "cuts out"? Does the engine die or does it feel boggy?
no only wen it wants tooAZ89two4Tsx wrote:Is the speedometer working?
yeah i got it scanned and it said the speed sensor circut is fualty?AZ89two4Tsx wrote:It should be the speed sensor then. That's my problem.
If not, maybe the ecu or cluster.
sensor circut or sumthin like that?dat925stunna wrote:and my EGR valve if f***ed too
auto ecu?AZ89two4Tsx wrote:It should be the speed sensor then. That's my problem.
