sil80drifter »
https://forums.nicoclub.com/sil80drifter-u622.html
Sat Nov 20, 2004 10:14 am
I can see how the rocker arms themselves may be hard to clean, but what about the rocker arm shafts? I think worst case scenario, i'll just get new rocker arms. Does it cost much to hot tank and clean all the parts, usually?
I am very new to the whole rings/bearings replacement business, so I woudl appreciate a few tips.Thanks so much for the already given info btw.
So let's say I have a block, it has 70k miles on it, the block itself right now it standing there with plastic in the oil pan (fully assembeld with crank/rods/pistons, nothing else). I don't know for sure, but I think the rings are in ok shape (I will replace them though) and pistons/rods are still ok to reuse, what should my next step be to find out whether the pistons/rods are ok?How do I find out what size rings to get, and whether the old ones were worn out much, or whether the sylinder walls were worn out much? I can't test compression because this block is outside of the car, just sitting there, so is there another way of testing the status of the rings/bearings??
I really want to take it all apart myself, then if nothing else is needed, get new rings/bearings, and put it all back myself as well, re-using the pistons/rods/crank. Is this realistic? Not from the side of me being able to, but whether I could pull it off with just replacing rings/bearings (and having the crank cleaned)? If I have the crank cleaned, will i need to get different size bearings than the ones that were on it originally?
I know my friend took apart his 50k mile block, had it redecked (it was a little warped on top) and then put everythign back together, reusing his rings and everything else. I thought I could do a similar procedure.
What do you think?
sil80
