sstomek »
https://forums.nicoclub.com/sstomek-u31323.html
Sat Oct 13, 2007 2:50 pm
The events that led up to this moment are as follows. After I finished up my KAE-T the car ended up running very well after some minor tuning. The only problem was a small coolant leak that was under the intake manifold. After taking off the manifold and fixing the leak we mounted everything back up.
The whole time we were pretty cautious because I was afraid of missing a vacuum hose. All the EGR stuff has been removed. After putting everything back together and turning on the car, it would start bog/terrible idle and die. when I unplug the MAF the car stays on so I am sure that there is a vacuum leak somewhere. However, I have checked every nook and cranny for a hanging or loose vacuum line and could find nothing. Which leads me to the possibility that when i unplugged the battery something happened to the SAFC(settings are still there but maybe something went haywire?).
Although all symptoms point to a vacuum leak, me and my bro have been hovering over the intake manifold, double and triple checking any loose ends and found none.
Any ideas?
-Tomek
