Ka24e turbo ??
1LoSX
Car: workin on my car
how much boost can a ka24e internals handle? builiding my engine and wanted some info before i started. has anyone built there internals already and running high boost?
george
Car: autocross
go to real nissan a they have crazy set ups for the ka24e good guys they know wuz up with the KA24E. stock internals wont take more than 10psi.
95_240sx
Car: My baby (car)
You would probably be best off getting in touch with a guy on here named Adamhu I believe. He has a ka24et I believe which he uses for AutoX and he is quite knowledgeable from what I can tell :-)
Rick
ADAMHU
i am running 12psi boost..have had it up to 14psi so far...
i don't see any real reason to go past 14psi in the road racing i am doing...since it is laying down 300ftlbs at 12psi already...
1LoSX
are you running that off of stock internals?? did you build your own kit or buy it??i would like to push some power after i build my internals - can ca18det 370cc injectors fit that too?? and i heard a 2nd gen 300zx fuel pump will fit also
JSPEC SilEighty
yeah like george said, check out http://www.realnissan.com
Tony Starks
JSPEC SilEighty,
ouch!that pic is funny as hellz....ROTFLMFAO!!!!!
mitch89fback
Where did you run the feed lines from for the turbo oil?
zb240sx-t
Car: 240SX
For oil feed line you have two options:
1. You can install "T" adapter in place of your oil pressure sending unit. One outlet will be for your feed line, one for sending unit.
2. You can drill a separate hole near your sending unit, thread it and install feed line there. I have it this way, got an adapter before but it leaked.
Hope it helps.:ylsuper
