KA24E turbo not running right
katurbo90
Car: 1990 240sx KA24E turbo
So I have a KA24E turbo with 450CC deatschwerks injectors running 7PSI a stage 2 cam a N60 MAF light weight fly wheel and stage 2 clutch. I just got my ECU tuned by Emance, I stuck it in with my N60 MAF and it was idling fine and running just fine. I took it out for a spin and it started not recognizing when I was giving it gas. Then it started dying when I left off the gas I had to pump it to keep it running. Any suggestions? TPS is what I was thinking but idk.
neverlift
did it run fine before emance?....
katurbo90
It ran but I could not go wide open throttle. Has error code 23 and 45.
neverlift
you have those codes now, with the emance tune? Sounds like the ecu is jacked if you now have codes.
