KA24E Turbo kit
mexicana
Car: 1991 D21 Hradbody
Does anyone have a kit for a ka24e? I want to turbo my truck its a 91. or just point me to the right place
ace0073
Car: 1969 datsun 510
i dont have a kit but i do have a set of new ross forged 8.5:1 ka24e pistons that im looking to get rid of. still in the box with no rings. called ross and rings are only $86.00. shoot me an email if you are interested and we can work it out. [email protected]
Brandon93240
Car: 1993 240sx
jgstools.com, they have a starter kit that has the manifold, downpipe elbow, turbo, oil lines, and a few other parts for around 1700. Its all high quality components. You'll have to fabricate your own intercooler pipes and downpipe to connect the elbow to your exaust but its very doable.
mexicana
i took a look at jgstools.com there one houre from were i live but the the turbo kit for the ka24e is kinda wiered becouse i have a much diiferent intake then there 240 progect car? does this mean i have to get a differnet intake or what? my intake is like a tbi type but it is the MPFI system
Brandon93240
Car: 1993 240sx
Jgs' project car is a s14, it comes with the dohc engine, your car has the sohc thats why the intake setups look differently. Theres a few people on here with pretty nice sohc turbo setups, if you search you can find them and ask them how they like their setup and parts used so you can get a better idea of what route you want to take.
mexicana
take a closer look its a SOHC.
Brandon93240
Car: 1993 240sx
I guess he has a single slammer now, I know he has a white s14 or did at one point.
Brandon93240
Car: 1993 240sx
I didn't realize you had a truck until just now. Yeah the intake is different, you can still make it work with what you have. I have a de in a 4x4 frontier that I built up that I'm waiting on my manifold to get here to turbo from jgs, but I got it from a member on here.
mexicana
if i could find that intake would that bolt up to my block?
Brandon93240
Car: 1993 240sx
Yes it would bolt up but you'd have to do some mod's to make it work with your harness and ecu. I'd just stick with what you have, it'll work.
mexicana
ive looked at it and was wondering how the heck do i adap the boost tube to it there really isnt a lipe to clamp to.
S13FX
Car: '69 l20b Dimeski :)
PICS.
But if you do have a true ITB setup, you either will have to make a plenum for it or switch back to stock one.
But with out pictures and more accurate info on your current set up it's hard to do anything.
Also if you could, you should download firefox which is a web browser. It has a great spell cheking capability which will greatly help you out, and in return makes tour posts a lot easier to read.
Don't worry I'm a horrible speller too and use it very often.
And Welcome to NICO..
Brandon93240
Car: 1993 240sx
I believe he has the factory setup which is just a single tb facing up towards the hood. You can get a tight radius mandrel bend or a low profile 90 degree silicone coupler to connect the cold piple to the tb.
S13FX
Brandon93240 wrote:I believe he has the factory setup which is just a single tb facing up towards the hood. You can get a tight radius mandrel bend or a low profile 90 degree silicone coupler to connect the cold piple to the tb.
Ahh From the way I read this post, he made it sound like he bought the car with some type of an ITB setup heh.
Brandon93240
Car: 1993 240sx
Yeah I hear you, the first time I read the post I didn't even realize that it was a truck and not a car.
mexicana
sorry about not clearifing it thouroughly it is stoke with the tb facing up.i can fab so i might be able to make something to adapt to it
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
throw on a 240sx ka24e intake manifold. I have a extra if you are interested. Email me if you are.
WDRacing
I built a turbo kit out of JGS stuff for a buddies hardbody. The intake mani is all different, the MAF is like part of the intake. It sucks really...
But a basic low boost kit like the JGS kit will work fine. We had his running 9;bs of boost with a FMU and a MSD BTM for timing retard.
Let me know if you need a hand, or suggestions.
WD
zero240se
Car: nissan 240sx se 96
you can u a holset turbo off and dodge ram diesel. it was in a sport compact mag. the guy got had 127hp thn with the turbo 266hp. try that.
jpadilla12
Car: 240sx
If your looking for quality parts for the SOHC check out OandJperformance.com . Great Parts and customer service. Ask for Omar, he is the man to talk too .They make custom Intake manifold and Turbo manifold for the SOHC. Better pics coming soon!! Check it out :
Zion8561
Car: 92 Nissan S13 Fastback
WDRacing wrote:I built a turbo kit out of JGS stuff for a buddies hardbody. The intake mani is all different, the MAF is like part of the intake. It sucks really...
WD
I am looking into a similar setup for my 97 Hardbody. If you have any pics that would be a huge help to see how you did it.
What turbo was used, and how was the performance after install?
vg33t
Car: s13 rb20
mexicana wrote:sorry about not clearifing it thouroughly it is stoke with the tb facing up.i can fab so i might be able to make something to adapt to it
A little work with a hack saw and some jb weld,you can make the air flow sensor into an adapter.
