Well the only cars with the KA24E engine were made mostly around 1990 as you probably know. They were the 240SX, Axxess, Hardbody Pickup and Stanza. Obviously the Stanza and 240 are not trucks, here are the C/R numbers I found:
240SX - 9.0:1
Axxess - 9.3:1
Pickup - 8.6:1
Stanza - 9.3:1
That's the info I found. If they are dished than they probably have a lower compression, which would rule out the Stanza and Axxess. So most likely you have the Hardbody Pickup pistons, which are 8.6:1, good for turbo applications!!
Hope this helps.
