ka24e truck and 240sx parts
Nvkreationz
Car: Cars
Are the engine and transmission interchangeable with the 240sx??i found a guy selling the truck for $250 and it has the same engine with less then 130k miles on it thanx guyz
masticatingcow
Car: 94 Mazda FD3S
If you're talking about the SOHC KA24E 240sx, then maybe. I don't know much about the SOHC models, but the DOHC KAs in the 240sx, Altima and Frontier have different heads. I would get the truck anyway, if only as a beater. If nothing else, you've got a cheap means of moving your 240sx parts around.
Nvkreationz
Car: Cars
yea its a SOHC
FliMSiCaL
Car: 1989 240sx 1994 sentra limited edition
the truck ka is different then the car ka in several ways. first the intake is totally different, but the 240 mani bolts up to it. internally, the crank is longer, the rods are a bit longer and the compression is lower, along with a few other things. change the intake and exhaust mani's and it should drop into a 240 with no problems.
