KA24E Trans-Diff Oil Change
DeltaZulu
Car: Basement Musician
I am trying to change the transmission and differantial gear oil of 90 240SXSE (stock). I just want to have an advice from expert on filling bolts. I located drain plugs of those two with no problem but I am having a trouble with filling bolts.
(1) For differential, the factory service manual shows both fill/drain bolts on the back of differential case but the filling plug of my 240SX is on the side of the case. Do I have to remove muffler to reach this plug?
(2) For transmission, filling plug is on the side of the case. It looks like the bolt is damamged by preivous owner(s). I heard that oil can be filled from the top. Can anyone verify this please?
Thank you in advance.
~*IdIoT bOx*~
Car: cars
For the transmission, i couldn't get my fill plug either. I just drained oil and put 2.4L in like the manual says. I filled thro the shifter hole.
As for the diff, fill plug and drain plug are booth on the back of the diff. Fill plugs is in the top right corner.
DeltaZulu
I will check the differential hole again.
Thanks again.
