ka24e transmission sr20det engine???
dull240sr
Car: 92 240sx se coupe with s14sr
Hey i was wondering if the rear transmission cover from the ka24e will fit on a s14 sr20det in the s13 chassis? i have an sr transmission but the space were the rear seal goes is gone. my drive shaft came out while i was towing the car and it busted up the end of my transmission. i cant afford another transmission right now so id like to know if the ka rear case will bolt to the sr bellhousing. any help would be appreciated.(so far i cant get a straight answer, some say yes some say no, but most just say its stupid and dont bother)
240_SeX
Car: 1992 240SX SE
The search button flashes for a reason...and you are that reason
Yes, it will. The SR trans is exctally the same as the KA with the exception of the bellhousing and a slightly diffrent 5th gear. you can swap the bellhousings and save youeself some time.
Next time please do some more searching
dull240sr
well thanks for the info. and just so u know, i did search. i searched several different sites, and just like i said i couldnt get a straight answer. i would rather know that it would definatly work before i waste my time taking them out of both cars and finding out that it wont work. yet again, thanks for giving me a straight answer, i really appreciate it. and sorry for wasting (your) time.
