Cool. Thanks for the kind words. I don't recall what I was smoking when I was last messing with the TPS, but I must have just been seeing what I wanted to see. Or perhaps my TPS is just flaky. I was going to make a permanent ground for it but this time the signal only dropped a few tenths of a volt with the new ground. Further testing of the TPS showed it is indeed bad.
I guess I'll replace the TPS and it's ground, redo the MAF ground, set the timing to where it's supposed to be, clear the ECU, and see where that gets me.
Do me a favor if you could? Merge this thread with that one -->
http://www.nicoclub.com/zerothread?id=80115
They're a part of the same episode and I had thought that one was dead when I thought to start this one.
Thanks again.
