ka24e to ka24de transmission, additional electrical plug problem
danield319
Car: 240sx
i got a full DE swap and i pulled out the crappy old E and i realized that the ka24E transmission only has 3 electical plugs and where the ka24DE has 4 plugs, what should i do about that?
xX RB Xx
Car: SE3P, FC3S, FC3C.
Don't worry about it.
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
you only need the one closest to the motor
its for the reverse lights
you will also need the speed sensor from the KAE so the gauge cluster reads correctly
(thats the one that goes into the bottom of the trans, with the wire you remove it with a ten mm wrench)
im sure you couldve found this with a little bit of searching
danield319
Car: 240sx
hbpignosePA wrote:you only need the one closest to the motor
i probably coulda but i suck at searching, and you helped me out so thank you and it might be alil problematic about removing that thing for the E transmission seeing as the plug wouldnt come off so i just cut the wires
hbpignosePA
90 Volvo 240 (sold)
its not the plug you cut
its that piece that is below the futherest circle you drew on the E picture
its a notch that sticks out and then has a wire
take the bolt out
it slides out
search for speed sensor if you need a visual
