dareo »
https://forums.nicoclub.com/dareo-u8796.html
Sat Jan 03, 2004 9:12 am
i'm considering this swap as well, if i can find an under 80k KA24DE with trans. We would need ecu, harness, power steering stuff i think. Isnt the powersteering different on this motor? You will need the cluster as well, for the tach. you could keep your original and do an aftermarket tach or something. Having the DE cluster would be nice cause it'd look all stock and stuff, plus it would display a correct odometer reading for that engine. (my 240s are exempt from odometer readings on their titles)
