ka24e to ka24de swap issue
240sxsd
Car: s13
couldn't find a post about my problem, hope someone can help me out
ka24de swapped on my 89 240sx, everything is hooked up turns on, its idling rough and when i step on gas a little it studers and shuts off. if i full throttle it it slowly starts reving up. i have no clue what it could be. everything is new on the car spark plugs and cables, distributor, ignition coil, maf sensor. any ideas??
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Have any codes? My first guess would be tps sensor bad or going out.
lebgangstah
Car: 1992 240sx s13
u said when u full throttle it quickly , mine did that but wouldnt turn off just bog out , i had a vacum leak in the intake check that out . or ur maf is wrecked , i cleaned mine and she started running amazing! ,
240sxsd
Car: s13
compactfean wrote:Have any codes? My first guess would be tps sensor bad or going out.
just checked the ecu blink codes, it gives code 55 (No malfunction recorded).
Could it have anything to do with Idle Air Control? I mean, if I hold the throttle JUST RIGHT, the car stays running. But if I let go of the throttle it dies.
Thanks for your prompt reply by the way, I appreciate it!
P.S. Any easy way to double check my TPS is working besides buying a brand new one?
compactfean
daily
Backprobe it. Make sure set at like .4 volts. Also make sure as you open the throttle body, the voltage smoothly goes up to 4.xx bolts.
95zenki man
Your dizzy might be a little off. I know mine was doing the same thing last night before i got the dizzy set right. Just set #1 to tdc and pull the dizzy and put it back in so its lining up with where it should be. I dont think a vac leak would play with the motor like that...
