S14 intake mani can still be used - Yes you will need the S13 exhaust mani, unless you get an S14 downpipe too, then you'd need new exhaust, so.....
For anything intake all you need is the plastic crap with the MAFS and I guess the airbox...
I didn't have A/C to begin with so I con't confirm any of that.
Tach is easy as was said above.
The P/S lines will look pretty ghetto when you bend 'em over, and the SOHC P/S resovoir is hard to get lined up also if you use the SOHC P/S pump (I'd recommend getting a DOHC pump + bracket...)
The throttle cable from SOHC works, but it crosses over the valve cover and also looks ghetto.
Oh, and I'd highly recommend using the S13 DOHC harness and ECU, unless you have an S14 and S13 FSM and are good at wiring...
Make sure to put the fuel lines on the right way and that kind of stuff... (I helped a guy out who had them on backwards... Fired up right away after I told him that...)
Thats about it... The S14 KA has a little more low-end torque, and a slightly lower rev-limit than the S13 KA - All in all, a fun motor :ylsuper ....for a KA....
