KA24E to KA24DE dash wiring
240trd
Car: 1990 nissan 240sx
I am trying to do a KA24DE swap and as you guys know the dssh harness is different! I really dont feel like splicing the wires to the clip do you know where i can get a custom clip made or find the wiring schematics??
James@CI
Car: 89 Nissan 240sx with SR20DET
Do you not have the KA24DE harness
240trd
yeah i do but the plug for the dash cluster and the wiring harness for the engine bay are different.
240trd
come on guys help me out here
240trd
this is bull**** how the hell am I supposed to do this? I cant find the schematics anywhere and a nissan enthusiast forum cant help! So your telling me that you guys did the swaps and automatically knew what wire went to where. I already know that thats some bull. there is no one out there in this forum that can help!
mach5camaross
Car: 90 240sx hatch KA24de-t
Do you know how to remove the pins from the connectors (plug ins)? If not ask around locally, its not to hard with a little tool thats real cheap. Remove the pins from the connector on the DE harness so all you have is the 8 or 9 wires with the pins. Take your original sohc harness and remove the connector that plugged into your dash harness. hold the connector so it will plug into your dash harness and instert wires into it so the colors match up to the dash side. you will have 3 or 4 wires left over that dont match up to anything on the sohc dash harness, tape these back thet are for the consult and you wont need them.
240trd
did you do the swap yourself? because every time i go to ask someone about it they say the wires are never the same in a nissan, and you have to find the wiring schematics to splice into them and hardwire them. well this is what I hear from JGY and Adrenaline ( both custom Nissan experts) if this is true then we will c but as far as i remember they are not color coded.
240trd
ok so i looked at it. there is 12 wires though and five of them go together, but where do the rest of them go cuz i really dont want to mess anything up?
placham
Car: 1992 Geo Prizm (4AFE)---Gone
1990 Nissan 240sx Coupe (RB20DET powered),
1994 Toyota Celica GT (3SGTE swapped), 1995 Nissan 240sx KA24DE,
2011 Nissan Sentra SER Spec-V
Pictures would really help here, to show which plug your talking about. I always though that ka24de and ka24e were a plug and play (talking about S13 ka24de and ka24e).
Personally I never swaped from KA24e to ka24de. I replaced my ECM plug,because I cracked my old one in half by accident. Took me about 30min to redo 2 plugs thats about like 60 pins for each plug. I used a smaller paper clip, get one that is made from harder wire, so it wont bend much.
By the way there is no reason to get mad, mostly you'll get input from members that did this before. I assume since your tackling this task, you must be familiar with electronics and wiring/harness and such.
Got to 240edge.com, there you will find wiring schematics for both ka24e and ka24de(S13 and S14) in ether FSM.
You know you need KA24DE tachometer, because your ka24e tach wont read correct with ka24de, right?.
240trd
well the tach is not a problem i baught a new one. but thanks for the site ill check it out
