KA24e to DE wiring problems?
hoosier240sx
Car: 1990 Nissan 240sx KA24DE
So I have the motor in. Everything is hooked up and the wires are connected but one. I bought a lower engine wiring harness for the KA24DE off FRsport.com and it seems that one connector is wrong. The wire for the coil is different. The female connector that is attached to the fuse box has 4 wires and 4 plugs on the inside. The connector FRsport gave me has 2...
What can I do to fix this? Is this the right lower wiring harness? The engine will crank but wont start. I'm thinking this is the problem since it's the coil connector. Is it possible that the SOHC and DOHC fuse boxes are different perhaps? I Don't have a clue :confused: . Any light on this would be great! :yesnod
Thanks in Advance guys,
Evan
