KA24E to a KA24DE??
Wert
Car: 1989 240sx coupe
i recently bought a 89 240 with a siezed engine. looking to do a cheap swap to get it back on the street. was thinking of putting the ka24de in it how hard and how much would this be???
bone_stock_240
Car: 1995 Infiniti Q45
It is not hard at all. Powersteering lines need a bit of modifying though. It should cost around 400 for everything, if you shop around and get good deals. Search for more detailed answers. There are a couple writeups in the technical section that you can look over.
edit:
Here is the linkhttp://www.nicoclub.com/articles.php?id=162443
Welcome to the club!
Wert
bone_stock_240 wrote:It is not hard at all. Powersteering lines need a bit of modifying though. It should cost around 400 for everything, if you shop around and get good deals. Search for more detailed answers. There are a couple writeups in the technical section that you can look over.
edit:
thanks man that's alot of help. just one question my car has heads up display can i keep that or do they not work together?
dickie
Car: Killer Turtle
you will need a DOHC tachometer which you can take from a 91-94 cluster and swap into yours.
nka24racr
Car: 91 acura integra, but missing my chuki......
Im thinking of swaping out my ka24e for a ka24de, i just bought my 240 a couple days ago, do i need to swap pcm's? and can i use the same wiring harness?
dickie
Car: Killer Turtle
you will need a new dohc wiring harness and ecu.
