ka24E timing to tdc help?
carkook
Im trying to set my ka24e to TDC. Is the right timing mark? I looked it up for the De but the timing pin is on the right side of the block, so im just making sure.
Goldeneagle
Car: 1992 240sx Coupe
You have it correctly.
Every mark to the left or to the right of the second notch, moving left to right, is an additional five degrees off of tdc. (IE: Third notch from the left is five degrees before top dead center, the first notch is five degrees after tdc, etc)
