180weaver wrote:I tried installing the pump and shaft with the punch mark matched up but it definitely was not pointing the rotor to the notch on the distributor at about 5 o'clock. I finally got the shaft and pump moved around though so that the rotor is pointing to that notch. So hopefully all is well and when the ecu comes in I will find out pretty quickly I imagine.
I did my chain and such when i built my motor, so im not 100% sure if the matchmarks on the oil pump line up once the pump is installed (as the end of the gear slides in, it possibly turns a little to line up with the gear), but it should definately start out lined up. And so long as the motor is still at TDC, and the rotor is lined up with that notch (showing you the #1 cylinder), then you should be ok.
Thanks for the compliment. I put a lot of work into my SOHC. Unfortunately, i am about to swap it. Into my recently acquired fastback. The coupe will be getting a CA18DET and eventually a Silvia facelift, while the fastback will get the built KA and 5sp swap. Dont worry, tho. I still love KA's. I just want a Silvia as well.
