ka24e timing question please help?
newboyspo
Car: 1990 240sx RED!!! Coupe
Hi, and thanks in advance for any help you can provide.
My timing chain guide busted in half last week so I swaped out the gears chain guide and tensioner, after I put it all back together and checked the timing it seems that I can't get above about 12 deg.? can I take the oil pump / dist out and move them 1 tooth over on the worm gear from the crank so that I can get up to 15 deg? (I used a set of pictures from here to check the cam/crank/rotor alignment rotor pointed back and down twards the front suspention, #1 at tdc, crank pully at 0 deg. cam alignment pin pointed up)
Thanksnewboyspo
InsanityInc
yes. You just got your distributor off a tooth when you put it back in. Moving it is fine.
NISTECH
cam pin alignment pin pointed up?? Should look like this on the cams.
EDIT: Removed picture due to lack of relevance and not paying attention.
newboyspo
Sorry about the mix-up,
I have a ka24e 1990 sohc
these are the pictures I used from this sight to align it..
newboyspo
NISTECH wrote:Here is another perspective
newboyspo
Thanks!!!
newboyspo!
Honda the inventer of the step through 90 now they want to race a Nissan? What's up with that?
NISTECH
Well I guess if I would have read the TITLE of the thread I would have realized that..lol
XxBLiNdxX
Car: 1990 Nissan 240sx
lol, those are my pictures. =) Glad I could help out.
