Truck »
https://forums.nicoclub.com/truck-u68614.html
Tue Apr 08, 2008 8:07 am
The car is a 1989 240sx sohc, with aprox. 180,000 miles.
The weekend before last I replaced my timing chain, tensioner, guide, and sprockets. While I did this, I went ahead and replaced my crank pulley, with a lightweight underdrive pulley. There are no oil or coolant leaks which leads me to beleive it was assembled correctly. The chain itself was matched to its marks.
However, after I had reassembled everything and flushed the oil, my car was having difficulty starting; sometimes it dies, but if I gas it a little once or twice, it will stay alive and drive. When I begin driving the car, it bucks alot for the first tries a clutch engagement, but afterwards, will accelerate smoothly. I should mention though, that the cars ignition was completely retarded(opposite of advanced, right?) just so that it would idle semi normally. Now, acceleration is very poor. And the car is much louder, with a different exhaust note.
Basically I have several theories, but would like some knowledge. I was wondering if a car could even run at say, 15 degrees after top dead center, stock ignition timing is 15 btdc. When I used a timing light, the marks were about just under 1 inch off, which leads me to two problems, either the crank pulleys timing marks were incorrect, or my timing is off. When I replaced the timing chain, I did put the engine at tdc, and the rotor was pointed at#1, which it still is. Right now I am waiting for the car to cool, when it does, I will drain the oil and turn the OIl pump/ distributor one notch retarded (once again opposite of advance).
One other addition to this long *** post, I tried to pull ECU codes, but I did not even see a screw to turn, or a light.
