KA24E Timing Chain Rattle
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Switched to Mobil1 5w30 rattle starts.Switched to Valvoling Durablend 10w30, no more rattle.
Was told by a Nissan tech friend of mine that I should run STP oil treatment along with 10w30, that'll make my engine purr. So far, he's right.
CPS
What kind of oil filter are you using? If it doesn't have the check valve in it to retain pressure when the engine is shut off, it will cause this problem.
Rev_D21
Nissan OEM filters.
